I have a 2TB drive (white light). I cannot get the Mionet software to recognize the drive. I have tried rebooting the drive, turning off my firewall (McAfee), allowing certain programs through the firewall, and anything else I can find in the WD knowledgebase. Nothing has made any difference.
One thing that seems significant is that the drive itself does not seem to be active on Mionet. When I access the drive directly through its web interface, I can see that the Mionet service shows its status as Stopped and Unregistered. The check box for Enable Mionet on Startup is selected, but a restart of the device makes no change.
Can someone tell me what needs to be done to make this work? I must be missing something basic here. None of the articles I have found so far describe how to get this up and running. They seem to assume it will all just work.
I bought “my book the world edition” 1 tb and it´s the same. When i did the acount on mionet it didn´t reconize the nas.
So i can´t have acess . I turned off my router firewall and nothing. It´s the same. Ihave to say that i`m using windows vista. Is there anybody can help me? (Status: Stopped / Unregistered) - but why ???
No dice. I installed the 64-bit Windows 7 version from the site. Nothing is changed. The drive still says Mionet is Stopped and Unregistered. The Start Mionet, Reetart Mionet, and Reset Mionet buttons do nothing.
This software appears to be useless, at least on Win 7. I could share folders on my hard drive, but that is not the main point.
I tried the same thing from Windows XP 32-bit. Same result. The drive is not detected, and the status is still Stopped and Unregistered. I am beginning to think I may have a problem with the drive itself.
I submitted a help request to WD a few days ago. No response yet.
That did work! I got response from WD that points to the 2.4.0.7 version of the firmware. The steps were the same, and now the Mionet tool functions properly.
Followed the steps and upgraded the MioNet on WD Sharespace, but no change: status=started/unregistered. Any other ideas? Having remote access was one important reason i bought this device
Hi there, been having the same problem with my Mionet stopped/unregistered. I was reading your posts and I noticed that my fitmware info reads out of the box: 1.1.18 with Mionet 2.3.9.13.
Where did you find the newer firmware for Mionet? Thanks and regards.
