Minimax (3-port usb HUB)
Can you connect a iomega minimax (3-Port USB HUB)?
The manual says “The WD TV HD Media Player does not support USB hubs.” :frowning:
The specifications  http://go.iomega.com/section?SID=21a40035547b061e355e2171a6c49ec0c32:4760&secid=76814#tech_specsItem_tab
I did try connect USB hub and had no luck. Looks WD USB ports are not capable of powering on USB drives using USB HUB.  I connected two seagate portable HDD to USB and tried , have no luck
