Okay I am having a few issues.
- Some movies the metathumb is coming down and is 0kb on my Network share. I can pick the same movie over and over again - E.G. Spiderman this one will alwyas have a metathumb of 0kb. I then go to Spiderman 2 and I get its metathumb just fine. E.G. I downloaded content informationation for Lord of the rings Fellowship of the rings just fine but not for Twin Towers
I have tried a) deleting the metathumb file and the XML file manually on the server for the movie and redownloading. I have tried b) removing the content info from the movie and then redownloading it. c) I have also done the above two deletion types and then turned around downloaded about 5 other movies metathumb information and it downloads just fine to go back ot said movies and STILL have a problem with them. d) I have gone into the xml files and found the URLS for the jpgs that I assume make up the metathumbs and verified that they are in fact in a site my PC can get to so its not a connection inssue there.
All movies have the similar 0kb metathumb information file issue. I also KNOW the SECOND I intiate the content download it will happen and on what movies because when I got to Update content information in the options it lists the movie I then cick on the green check mark for the movie and it just hangs with the green mark for a few minutes until it is gone and I get the XML and I get tthe 0kb metadata file. I am on the latest firmware ofthe WD TV Live hooked up to a network share which has MORE than enough space (I am at about only 50% utilization of a 2TB drive and the drive tests just fine).
I have a bunch of directories I have seperated things into. E.G. Matrix I have all 3 Matrix movies into it. How do I determine which of the pictures the Matrix folder shows or even do a custom picture? I also have a Kids Movies folder a Wife Movies folder and of course my Movies section as well as a TV Shows section. I would love to put in a custom thumbnail but a) don’t know the size of the picture that needs to go in there and b) I am not sure of the layout? Do I have ot add another XML and a metathumb file for these as well?
Is there any way to grab content data for ALL movies in a folder? Its rather cumbersome to grab it for each individual movie? Maybe make it give a warning asking if your sure and then prompt with a downloading for X movie these are your choices and then allow you to skip if you want to for some insane reason NOT have the content information on a specific movie? if not they may want to look at that for future releases those with a large media library may love that feature instead of one offing so many movies.
How does one create a custom metathumb is it simply pull down a jpg and rname it to folder.metathumb? (Kind of goes back to my wanting to create for folders on point 2)
i notice the plot and overview and anything that is larger content than a single line and scrolls ends up scrolling WAY too fast to be seen. Is there any setting (I have not found it in the setup anyware) that I can set this GLOBALLY. I do not want to have to edit XML files to do this if can be avoided (I am assuming its not in the xml anyware because I do not see any setting for it there).
