Hi all looking for some help,
I have searched for an answer but have been unable to find any clear answers. I bought my wd tv live media hub so i could watch my files through it onto my tv in my bedroom while also having the capability to stream to my ps3 in the living room. However it does not work very well with the ps3, the content is not organized the same way, and it does not display all of my files. so first off is there a proper way to organize your files.
mine is setup internal>ps3>movies
tv series
other
but it will only display the movies when i browse by folder. second when i try to play the movies it lags and then says datat not supported, when i know they will play directly from an external hard drive i have used before. so i know that the file format should be supported. i am frustrated because the hub advertises the ability to stream to the ps3 without lag, but it is not. I am using a netgear wndr37av which is a dual band gigabit router made specifically for this type of streaming. the hub is plugged into the router and the ps3 is connected through the wireless network. any advice is appreciated. thanks
