macOS Catalina 64bit WD not works?
I have a WD 6TB and since I have updated my MAC (mac OS Catalina) I can’t open My WD ? Did you know if an updated is now available ? I didn’t found ?
thanks for you help
Hello I have same your problem after updating to Catalina my wd cloud not supported
I have problem with my bok thunderbolt duo
Did it work for you, I still facing some issue. MyCFAvisit
