I just purchased a live hub on line from the US and never thought to check whether it works with the 220 voltage in UK. Can you assist?
Wayne Hann
Wayne Hann
You need to have a look at the power adapter itself - most of them these days are 100-240v.
According to the product specs it can accept 100-240V @50-60Hz so it should be fine.
Wayne Hann
Yes it does
just get the fix for adpater
I did the same thing
bought it in States, saved like 40% EU price
