Hi, I had a unit as a back up in my network. The switch I was using blocked the VLAN that managed the IP of the drive, so I can’t access the data and the recovery email is lost. I’ve dismantled the drive in order to gain access but didn’t work neither.
What do you recommend?
Thanks!!!
Linuxmint. A usb stick and some free time… Mount the Eternal HD with DISKS. You will find out its /dev/sdba1 or whatever from DISKS. Once this is acheived then setup a s3cmd its what i use/ S3cmd sync /shares/ S3"Bucket &&
I bought an offline cloner, wavlink about 27USD
