Dear All,
My iomega 1TB usb drive cable pin broke from enclosure circuit,
I bought new case of WD Elements and now windows is showing RAW drive,
I have tried many softwares like testdisk etc but failed … only R-Studio showed me correctly my three drives and the data is fully intact.
Data is huge on 1Tb and I have this backup in different places which will be headache,
Is there any way I can fix Partition table with some software or something.
Any help will be appreciated.
Attaching screenshot of R-Studio and dmde.
[Deleted]
Regards,
Amir.
