Hi all… i was reformatting my computer yesterday and i accidentally chose and re-format my WD smartware…
and now when i put the USB into my computer… it doesn’t autostart anymore… and when i put files inside it… it doesn’t go thru… does anyone have a fix for this??
ok all you have to do is just reinstall ur wd smart ware form the web site . look up ur hard drive the sofeware and install to that hard drive and it should work give me a sulotion check if it works
ok ive been looking about missing porition and had no luck there are tons of back up software and locking software out there but call wd and ask about it
okay… so installed everything and when i plug it pops out right away…
but when i click " Setup Drive " it says " No writable WD smartware Partition found on your My Book Essentials drive"
There is no writable WD SmartWare partition available on this WD drive.
This can occur if you are attempting to write to a WD drive formatted for a different operating system, or if the drive is locked.
Please make sure that this WD drive is formatted for the operating system you are currently working on, and that the drive is unlocked.
So what should i do next??
Was your drive locked with a password before you reformatted? If so, then you need to disable the password. Otherwise, you can try updating the drive with the latest firmware, and you can try repartitioning and reformatting the drive, using SmartWare to see if that works.
