Hey everyone, I have a locked folder in my computer.
However, the WD LIVE TV HUB is showing the locked foler as “Control Panel (then a bunch of numbers/letters)”
If you enter the folder, you see all my hidden files. I tried deleting the folder from the WD but it gave me error message. I even relocated my locked folder into a different location, but it is still showing in the old location as before in the WD. Then I deleted the locked folder, but it is still showing.
I re-sync today after deleting, but it is still showing.
I even did a factor reset, but it is still showing.
Please hlep.
