How to move an usb drive connected to MyCloud
Hi disk1,
Do you want to safely remove the external drove connected to the My Cloud?
Yes
Hi disk1,
You can safely remove the drive from the dashboard. Access the dashboard and at the top you would see the USB icon where you can safely remove the connected USB. Please refer to the link given below in order to know how to access the dashboard.
Hi Alex.S
Thank you. Ir works.
