The “qbdbmgrn not running on this computer” error typically occurs when QuickBooks Database Server Manager (qbdbmgrn) is not running on a multi-user setup. To resolve this:
- Restart QuickBooks Database Server Manager:
- Open Run (Windows + R), type services.msc, and press Enter.
- Find QuickBooksDBXX (XX denotes your version), right-click, and select Start.
- Update Windows Firewall Settings:
- Ensure the firewall isn’t blocking qbdbmgrn. Add QuickBooks ports manually to allow connectivity.
- Repair QuickBooks:
- Go to the Control Panel, select Programs and Features, and find QuickBooks. Click Uninstall/Change and choose Repair.
- Reboot the Server:
- Restarting the server can refresh the database services.
If the issue persists, consider reinstalling the QuickBooks Database Server Manager.
