the wifi network I have access to at my office requires both a login and a password.
The connection window only allows to enter a password.
Is there a solution ?
Thanks.
Thanks.
The WiFi connection was designed to connect to a home WiFi setup, not a corporate setup. It supports WPA and WPA2 security. You can ask your IT department if there is a guest or public WiFi you can connect to instead.
