Wondering if anyone has any suggestions for my problem after connecting a 3rd device. I started out with just the 2 and was getting speeds of 32mbps and after adding the 3rd one the original 2nd unit is now only getting 12-16mbps and the 3rd one I added is getting the 32mbps. I synced them all several times… unplugged and did everything over and over again and nothing seems to be changing. Any suggestions?? Thanks
Have you tried connecting all of them to the same wall socket?
Yes nothing changed
