Hi I just bought a brand new 1TB blue and used it for less than 48 hours but the WD smart info shows it as used out of warantee. Am I reading it wrong or is it giving false info?
I bought it from Amazon Canada, not a reseller but Amazon.
What should I do? Any help appreciated!
WD-Smart|470x500
I don’t know why my uploaded screen grab is not showing.
Hi SuperEye,
https://support.wdc.com/support/case.aspx?lang=en The link below will allow you to call support.
Hi Brandon. Thanks but I think I was reading the info wrong. All is OK I believe.
