Help with my passport ultra
sorry I have no idea if this is where I post this but I can’t seem to figure this site out.
I just bought a ‘my passport ultra’ and have no idea how to use it. I tried reading a user guide BUT doesn’t actually tell me how to use it.
when I plug it in the file opens and thats it.
how do I use it, how do I store stuff on it, what is the use of this site and WD site mmmm???
thanks
christine
If you are looking to use your Passport Ultra as a storage device then I recommend you take a look at this link.
How to move or copy files from one hard drive to another in Windows
If you want to use it a backup drive for you computer files then you need to install WD Smartware and then Run a backup.
Check page # 22 of the WD Smartware user’s manual.
