I use Picasa to generate a 1080p wmv file from my photos. My WDTV Live hub will not play the file. So I try to use handbrake and select the high profile and mkv. Still does not work. I use handbrake all the time to convert DVDs and create 720p files with no problem. Any ideas on what settings to use to convert the 1080p wmv file to something that the Live Hub will play? I can provide the mediainfo outputs if necessary. Thanks.
Here it is. Picasa gives my no other output options so I’m stuck with this format:
General
Complete name : J:\JaysPictures\Picasa\Movies\Greece Athens Movie.wmv
Format : Windows Media
File size : 164 MiB
Duration : 4mn 20s
Overall bit rate mode : Variable
Overall bit rate : 5 289 Kbps
Maximum Overall bit rate : 7 707 Kbps
Encoded date : UTC 2011-11-17 20:24:50.827
Video
Format : WMV2
Codec ID : WMV2
Codec ID/Info : Windows Media Video 8
Description of the codec : Windows Media Video V8
Duration : 4mn 20s
Bit rate mode : Variable
Bit rate : 5 119 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.082
Stream size : 159 MiB (97%)
Language : English (US)
Audio
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 9.2 - 64 kbps, 44 kHz, stereo (A/V) 1-pass CBR
Duration : 4mn 20s
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 1.99 MiB (1%)
