since some time i have the problem that after some time my MyCloud starts two /usr/bin/find which are consuming a lot of CPU load.
After restarting the MyCloud again the jobs are gone.
But they reappear some days later again using the CPU.
I have disabled the wd stuff all the time i have the MyCloud ( /etc/init.d/wdmcserverd stop, /etc/init.d/wdphotodbmergerd stop ). This was always working fine until this strange find jobs appeared.
Top is looking like:
32297 32296 nobody R N 3968 0.7 1 52.3 /usr/bin/find /
13408 13407 nobody R N 3968 0.7 0 42.8 /usr/bin/find /
The complete find statement is:
13398 root 4288 S N su nobody -s /bin/sh -c /usr/bin/find / -ignore_readdir_race \( -fstype
NFS -o -fstype nfs -o -fstype nfs4 -o -fstype afs -o -fstype binfmt_misc -o -fstype proc -o -fstype
smbfs -o -fstype autofs -o -fstype iso9660 -o -fstype ncpfs -o -fstype coda -o -fstype devpts -o -fstype
ftpfs -o -fstype devfs -o -fstype mfs -o -fstype shfs -o -fstype sysfs -o -fstype cifs -o -fstype lustre_lite
-o -fstype tmpfs -o -fstype usbfs -o -fstype udf -o -fstype ocfs2 -o -type d -regex '\(^/tmp$\)\|\
(^/usr/tmp$\)\|\(^/var/tmp$\)\|\(^/afs$\)\|\(^/amd$\)\|\(^/alex$\)\|\(^/var/spool$\)\|\(^/sfs$\)\|\(^/media$\)\|\
(^/var/lib/schroot/mount$\)' \) -prune -o -print0
13407 nobody 1632 S N sh -c /usr/bin/find / -ignore_readdir_race \( -fstype NFS -o -fstype nfs -
o -fstype nfs4 -o -fstype afs -o -fstype binfmt_misc -o -fstype proc -o -fstype smbfs -o -fstype autofs -
o -fstype iso9660 -o -fstype ncpfs -o -fstype coda -o -fstype devpts -o -fstype ftpfs -o -fstype devfs -o
-fstype mfs -o -fstype shfs -o -fstype sysfs -o -fstype cifs -o -fstype lustre_lite -o -fstype tmpfs -o -
fstype usbfs -o -fstype udf -o -fstype ocfs2 -o -type d -regex '\(^/tmp$\)\|\(^/usr/tmp$\)\|\
13408 nobody 3936 R N /usr/bin/find / -ignore_readdir_race ( -fstype NFS -o -fstype nfs -o -fstype
nfs4 -o -fstype afs -o -fstype binfmt_misc -o -fstype proc -o -fstype smbfs -o -fstype autofs -o -fstype
iso9660 -o -fstype ncpfs -o -fstype coda -o -fstype devpts -o -fstype ftpfs -o -fstype devfs -o -fstype
mfs -o -fstype shfs -o -fstype sysfs -o -fstype cifs -o -fstype lustre_lite -o -fstype tmpfs -o -fstype
usbfs -o -fstype udf -o -fstype ocfs2 -o -type d -regex \(^/tmp$\)\|\(^/usr/tmp$\)\|\(^/var/tmp$\)\|\
(^/afs$\)\|\(^/amd$\)\|\(^/alex$\)\|\(^/var/spool$\)\|\(^/sfs$\)\|\(^/media$\)\|\(^/var/lib/schroot/mount$\) ) -
prune -o -print0
32282 root 4288 S N su nobody -s /bin/sh -c /usr/bin/find / -ignore_readdir_race \( -fstype
32296 nobody 1632 S N sh -c /usr/bin/find / -ignore_readdir_race \( -fstype NFS -o -fstype nfs -
32297 nobody 3968 R N /usr/bin/find / -ignore_readdir_race ( -fstype NFS -o -fstype nfs -o -fstype
prune -o -print0
I hope someone can tell me where this jobs are coming from.
The user looks also strange with nobody?
Thanks and best regards,
Stefan
Next time this happens. 32297 is the process id of the current process. 32296 is the process id o the process that started 32297. So show the name of the process that started the find.
Thanks rac8006,
if i try to find the root job, perhaps it is some cron job?
What i did:
root@WDMyCloud root # top
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
5641 5640 nobody R N 3968 0.7 0 47.9 /usr/bin/find / -ignore_readdir_race ( -fstype NFS -o -
16555 16554 nobody R N 5568 1.0 1 46.7 /usr/bin/find / -ignore_readdir_race ( -fstype NFS -o -
When i search for 5641 or 5640 i only get other finds.
So i did:
root@WDMyCloud root # ps -ef | grep find
5585 root 1632 S N {updatedb.findut} /bin/sh /usr/bin/updatedb.findutils
5595 root 1632 S N {updatedb.findut} /bin/sh /usr/bin/updatedb.findutils
5631 root 4288 S N su nobody -s /bin/sh -c /usr/bin/find / -ignore_readdir_race \( -fstype NFS
5640 nobody 1632 S N sh -c /usr/bin/find / -ignore_readdir_race \( -fstype NFS -o -fstype nfs -o
5641 nobody 4000 R N /usr/bin/find / -ignore_readdir_race ( -fstype NFS -o -fstype nfs -o -fstype
16497 root 1632 S N {updatedb.findut} /bin/sh /usr/bin/updatedb.findutils
16508 root 1632 S N {updatedb.findut} /bin/sh /usr/bin/updatedb.findutils
16545 root 4288 S N su nobody -s /bin/sh -c /usr/bin/find / -ignore_readdir_race \( -fstype
16554 nobody 1632 S N sh -c /usr/bin/find / -ignore_readdir_race \( -fstype NFS -o -fstype nfs -
16555 nobody 5568 R N /usr/bin/find / -ignore_readdir_race ( -fstype NFS -o -fstype nfs -o -fstype
28195 root 2592 S grep find
When searching for 1632 i got a lot of jobs started by 1632 but no root job with 1632:
Please see:
PID USER VSZ STAT COMMAND
1 root 2560 S init
2 root 0 SW [kthreadd]
3 root 0 SW [ksoftirqd/0]
5 root 0 SW< [kworker/0:0H]
7 root 0 SW [migration/0]
8 root 0 SW [rcu_bh]
9 root 0 SW [rcu_sched]
10 root 0 SW [migration/1]
11 root 0 SW [ksoftirqd/1]
13 root 0 SW< [kworker/1:0H]
14 root 0 SW< [khelper]
15 root 0 SW [kdevtmpfs]
16 root 0 SW< [netns]
240 root 0 SW< [writeback]
242 root 0 SW< [bioset]
244 root 0 SW< [kblockd]
252 root 0 SW< [ata_sff]
262 root 0 SW [khubd]
271 root 0 SW< [md]
361 root 0 SW< [rpciod]
373 root 0 SW [kswapd0]
374 root 0 SW [fsnotify_mark]
375 root 0 SW< [nfsiod]
376 root 0 SW< [cifsiod]
378 root 0 SW< [xfsalloc]
379 root 0 SW< [xfs_mru_cache]
380 root 0 SW< [xfslogd]
381 root 0 SW< [crypto]
404 root 0 SW [ocf_0]
405 root 0 SW [ocf_ret_0]
406 root 0 SW [ocf_1]
407 root 0 SW [ocf_ret_1]
548 root 0 SW [scsi_eh_0]
551 root 0 SW [scsi_eh_1]
567 root 0 SW [spi0]
656 root 0 SW< [kcryptd]
669 root 0 SW< [deferwq]
686 root 0 SW [scsi_eh_2]
692 root 0 SW [scsi_eh_3]
693 root 0 SW [usb-storage]
698 root 0 SW [scsi_eh_4]
699 root 0 SW [usb-storage]
738 root 0 SW< [kworker/0:1H]
749 root 0 SW [jbd2/sda3-8]
750 root 0 SW< [ext4-dio-unwrit]
753 root 0 SW [jbd2/sda7-8]
754 root 0 SW< [ext4-dio-unwrit]
767 root 0 SW< [loop0]
1012 root 0 SW< [kworker/1:1H]
1145 root 2528 S xmldb -n config
1148 root 2240 S xmldb -n config -s /var/run/xmldb_sock_wto
1201 root 848m S /usr/local/restsdk/restsdk-server -device-kind alpha
1496 root 2560 S /sbin/udhcpc -R -r 192.168.69.111 -i egiga0 -x hostname WDMyCloud -p
1606 root 1920 S /usr/sbin/syslogd -r -m 0 --rt_line 800
1689 root 2048 S mserver
1708 root 13920 S mail_daemon
1758 root 0 SW< [bioset]
1759 root 0 SW [md0_raid1]
1774 root 0 SW [jbd2/sda4-8]
1775 root 0 SW< [ext4-dio-unwrit]
1782 root 2464 S noip2 -b -f 34560
1798 root 10880 S sysinfod
1801 root 2240 S xmldb -n config -s /var/run/xmldb_sock_sysinfo -p
1917 messageb 7872 S /usr/bin/dbus-daemon --system
1920 root 8576 S avahi-daemon: running [WDMyCloud.local]
2097 root 5120 S /usr/sbin/sshd -f /etc/ssh/sshd_config
2117 root 1856 S lld2d egiga0
2207 root 4480 S set_pwm
2367 root 0 SW [kworker/1:3]
2473 root 0 SW [jbd2/sdb1-8]
2474 root 0 SW< [ext4-dio-unwrit]
2712 root 0 SW [jbd2/sdc1-8]
2713 root 0 SW< [ext4-dio-unwrit]
2813 admin 52128 S smbd -D
2814 root 51488 S smbd -D
2955 root 0 SW [jbd2/sdd1-8]
2956 root 0 SW< [ext4-dio-unwrit]
3302 root 3552 S sevcd
3392 root 57728 S httpd -f /usr/local/apache2/conf/httpd.conf -k graceful
3431 root 6976 S chk_io
3445 root 5120 S temperature_monitor
3498 root 5056 R system_daemon
3506 root 7680 S N /usr/local/orion/communicationmanager/communicationmanager -f 120 -l 5
3544 root 2560 S init
3836 root 0 SW [jbd2/sda2-8]
3837 root 0 SW< [ext4-dio-unwrit]
4078 root 2048 S /usr/local/twonky/twonkystarter -D -ip 192.168.69.111 -httpport 9000 -appdata /mnt/HD/HD_a2/.twonkymedia -logfile /mnt/HD/HD_a2/.twonkymedia/twonkymedia-log.txt
4080 root 64416 S /usr/local/twonky/twonkyserver -D -ip 192.168.69.111 -httpport 9000 -appdata /mnt/HD/HD_a2/.twonkymedia -logfile /mnt/HD/HD_a2/.twonkymedia/twonkymedia-log.txt
4208 root 95520 S upnp_nas_device -webdir /etc/upnp
4225 root 0 SW [knetatop]
4260 root 3712 S apkg
4265 root 2560 S {mysqld_safe} /bin/sh /usr/bin/mysqld_safe --user=root --datadir=/mnt/HD_a4/.@database@
4426 root 27840 S /usr/libexec/mysqld --basedir=/usr --datadir=/mnt/HD_a4/.@database@ --user=root --log-error=/mnt/HD_a4/.@database@/WDMyCloud.err --pid-file=/mnt/HD_a4/.@database@/WDMyCloud.pid
4521 root 14240 S /usr/local/bin/wdnotifier
4535 root 177m S /mnt/HD/HD_a2/Nas_Prog/plexmediaserver/binaries/Plex Media Server
4593 root 107m S N {Plex Script Hos} Plex Plug-in [com.plexapp.system] /mnt/HD/HD_a2/Nas_Prog/plexmediaserver/binaries/Resources/Plug-ins-e67a4e892/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.18.2.2058-e67a4e892 /mnt/HD/HD_a2/Nas_Prog/plexmediaserver/binaries/Resources/Plug-ins-e67a4e892/System.bundle
4821 root 49856 S smbd -D
4823 root 53664 S smbd -D
4837 root 24576 S nmbd -D
5002 root 2432 S /usr/sbin/rpcbind
5007 root 0 SW [lockd]
5008 root 0 SW [nfsd]
5009 root 0 SW [nfsd]
5010 root 0 SW [nfsd]
5011 root 0 SW [nfsd]
5012 root 0 SW [nfsd]
5013 root 0 SW [nfsd]
5014 root 0 SW [nfsd]
5015 root 0 SW [nfsd]
5017 root 2624 S /usr/sbin/rpc.mountd
5019 root 2240 S /usr/sbin/rpc.statd
5262 root 4352 S chk_hotplug
5270 root 2240 S xmldb -n config -s /var/run/xmldb_sock_usbdev_info
5273 root 52736 S /mnt/HD/HD_a2/Nas_Prog/plexmediaserver/binaries/Plex Tuner Service /mnt/HD/HD_a2/Nas_Prog/plexmediaserver/binaries/Resources/Tuner/Private /mnt/HD/HD_a2/Nas_Prog/plexmediaserver/binaries/Resources/Tuner/Shared 1.18.2.2058-e67a4e892 32600 /waitmutex
5411 root 4128 S {cron} /usr/sbin/CRON
5418 root 1632 S /bin/sh -c test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
5419 root 1568 S run-parts --report /etc/cron.daily
5577 root 1632 S {locate} /bin/sh /etc/cron.daily/locate
5596 root 6080 S N /usr/bin/sort -z -f
5597 root 1632 S N /usr/lib/locate/frcode -0
5631 root 4288 S N su nobody -s /bin/sh -c /usr/bin/find / -ignore_readdir_race \( -fstype NFS -o -fstype nfs -o -fstype nfs4 -o -fstype afs -o -fstype binfmt_misc -o -fstype proc -o -fstype smbfs -o -fstype autofs -o -fstype iso9660 -o -fstype ncpfs -o -fstype coda -o -fstype devpts -o -fstype ftpfs -o -fstype devfs -o -fstype mfs -o -fstype shfs -o -fstype sysfs -o -fstype cifs -o -fstype lustre_lite -o -fstype tmpfs -o -fstype usbfs -o -fstype udf -o -fstype ocfs2 -o -type d -regex '\(^/tmp$\)\|\(^/usr/tmp$\)\|\(^/var/tmp$\)\|\(^/afs$\)\|\(^/amd$\)\|\(^/alex$\)\|\(^/var/spool$\)\|\(^/sfs$\)\|\(^/media$\)\|\(^/var/lib/schroot/mount$\)' \) -prune -o -print0
5640 nobody 1632 S N sh -c /usr/bin/find / -ignore_readdir_race \( -fstype NFS -o -fstype nfs -o -fstype nfs4 -o -fstype afs -o -fstype binfmt_misc -o -fstype proc -o -fstype smbfs -o -fstype autofs -o -fstype iso9660 -o -fstype ncpfs -o -fstype coda -o -fstype devpts -o -fstype ftpfs -o -fstype devfs -o -fstype mfs -o -fstype shfs -o -fstype sysfs -o -fstype cifs -o -fstype lustre_lite -o -fstype tmpfs -o -fstype usbfs -o -fstype udf -o -fstype ocfs2 -o -type d -regex '\(^/tmp$\)\|\(^/usr/tmp$\)\|\(^/var/tmp$\)\|\(^/afs$\)\|\(^/amd$\)\|\(^/alex$\)\|\(^/var/spool$\)\|\(^/sfs$\)\|\(^/media$\)\|\(^/var/lib/schroot/mount$\)' \) -prune -o -print0
5641 nobody 4000 R N /usr/bin/find / -ignore_readdir_race ( -fstype NFS -o -fstype nfs -o -fstype nfs4 -o -fstype afs -o -fstype binfmt_misc -o -fstype proc -o -fstype smbfs -o -fstype autofs -o -fstype iso9660 -o -fstype ncpfs -o -fstype coda -o -fstype devpts -o -fstype ftpfs -o -fstype devfs -o -fstype mfs -o -fstype shfs -o -fstype sysfs -o -fstype cifs -o -fstype lustre_lite -o -fstype tmpfs -o -fstype usbfs -o -fstype udf -o -fstype ocfs2 -o -type d -regex \(^/tmp$\)\|\(^/usr/tmp$\)\|\(^/var/tmp$\)\|\(^/afs$\)\|\(^/amd$\)\|\(^/alex$\)\|\(^/var/spool$\)\|\(^/sfs$\)\|\(^/media$\)\|\(^/var/lib/schroot/mount$\) ) -prune -o -print0
5793 106 4960 S /usr/bin/dbus-daemon --system
5819 root 3232 S /usr/sbin/cron
5840 105 55968 S /usr/bin/minidlnad -f /etc/minidlna.conf -P /run/minidlna/minidlna.pid
7141 root 0 SW [scsi_eh_5]
7142 root 0 SW [usb-storage]
8183 root 0 SW [jbd2/sde1-8]
8187 root 0 SW< [ext4-dio-unwrit]
8539 root 4960 S scheddler
9703 root 0 SW [kworker/u4:2]
16324 root 4128 S {cron} /usr/sbin/CRON
16331 root 1632 S /bin/sh -c test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
16334 root 1568 S run-parts --report /etc/cron.daily
16489 root 1632 S {locate} /bin/sh /etc/cron.daily/locate
16509 root 6080 S N /usr/bin/sort -z -f
16510 root 1632 S N /usr/lib/locate/frcode -0
16545 root 4288 S N su nobody -s /bin/sh -c /usr/bin/find / -ignore_readdir_race \( -fstype NFS -o -fstype nfs -o -fstype nfs4 -o -fstype afs -o -fstype binfmt_misc -o -fstype proc -o -fstype smbfs -o -fstype autofs -o -fstype iso9660 -o -fstype ncpfs -o -fstype coda -o -fstype devpts -o -fstype ftpfs -o -fstype devfs -o -fstype mfs -o -fstype shfs -o -fstype sysfs -o -fstype cifs -o -fstype lustre_lite -o -fstype tmpfs -o -fstype usbfs -o -fstype udf -o -fstype ocfs2 -o -type d -regex '\(^/tmp$\)\|\(^/usr/tmp$\)\|\(^/var/tmp$\)\|\(^/afs$\)\|\(^/amd$\)\|\(^/alex$\)\|\(^/var/spool$\)\|\(^/sfs$\)\|\(^/media$\)\|\(^/var/lib/schroot/mount$\)' \) -prune -o -print0
16554 nobody 1632 S N sh -c /usr/bin/find / -ignore_readdir_race \( -fstype NFS -o -fstype nfs -o -fstype nfs4 -o -fstype afs -o -fstype binfmt_misc -o -fstype proc -o -fstype smbfs -o -fstype autofs -o -fstype iso9660 -o -fstype ncpfs -o -fstype coda -o -fstype devpts -o -fstype ftpfs -o -fstype devfs -o -fstype mfs -o -fstype shfs -o -fstype sysfs -o -fstype cifs -o -fstype lustre_lite -o -fstype tmpfs -o -fstype usbfs -o -fstype udf -o -fstype ocfs2 -o -type d -regex '\(^/tmp$\)\|\(^/usr/tmp$\)\|\(^/var/tmp$\)\|\(^/afs$\)\|\(^/amd$\)\|\(^/alex$\)\|\(^/var/spool$\)\|\(^/sfs$\)\|\(^/media$\)\|\(^/var/lib/schroot/mount$\)' \) -prune -o -print0
16555 nobody 5568 R N /usr/bin/find / -ignore_readdir_race ( -fstype NFS -o -fstype nfs -o -fstype nfs4 -o -fstype afs -o -fstype binfmt_misc -o -fstype proc -o -fstype smbfs -o -fstype autofs -o -fstype iso9660 -o -fstype ncpfs -o -fstype coda -o -fstype devpts -o -fstype ftpfs -o -fstype devfs -o -fstype mfs -o -fstype shfs -o -fstype sysfs -o -fstype cifs -o -fstype lustre_lite -o -fstype tmpfs -o -fstype usbfs -o -fstype udf -o -fstype ocfs2 -o -type d -regex \(^/tmp$\)\|\(^/usr/tmp$\)\|\(^/var/tmp$\)\|\(^/afs$\)\|\(^/amd$\)\|\(^/alex$\)\|\(^/var/spool$\)\|\(^/sfs$\)\|\(^/media$\)\|\(^/var/lib/schroot/mount$\) ) -prune -o -print0
18839 root 0 SW [kworker/0:2]
20410 root 8192 S crond
22370 root 0 SW [kworker/u4:0]
24624 root 62688 S httpd -f /usr/local/apache2/conf/httpd.conf -k graceful
25653 root 7424 S < /usr/bin/atop -a -w /var/log/atop/atop_current 60
25799 root 0 SW [kworker/0:0]
25972 root 62656 S httpd -f /usr/local/apache2/conf/httpd.conf -k graceful
26441 root 62688 S httpd -f /usr/local/apache2/conf/httpd.conf -k graceful
26550 root 2624 S N {openvpn} /bin/bash /usr/sbin/openvpn /usr/local/orion/openvpnclient/client.ovpn
26561 root 5088 S N /usr/sbin/openvpn.bin /usr/local/orion/openvpnclient/client.ovpn
26572 root 0 SW [kworker/1:1]
26997 root 4384 S /usr/bin/rotatelogs -n 2 /var/log/apache2/web_error.log 256K
26999 root 4384 S /usr/bin/rotatelogs -p /usr/local/sbin/rotateApache.sh -n 2 /var/log/apache2/access.log 200K
27000 root 4384 S /usr/bin/rotatelogs -p /usr/local/sbin/rotateApache.sh -n 2 /var/log/apache2/access_ssl.log 200K
27406 root 0 Z [rotateApache.sh]
27448 root 5120 S sshd: sshd@notty
27458 root 2560 S sh -c /usr/bin/sftp-server
27459 root 4480 S /usr/bin/sftp-server
27465 root 8352 S sshd: sshd@ttyp0
27474 root 2720 S -sh
27922 root 0 SW [kworker/1:0]
27962 root 0 SW [kworker/0:1]
28704 root 8224 R ps -ef
Any Idea?
Best regards,
Stefan
Ok, i think i found it.
The job was started from the additional debian installation.
It is called locate and does “cron script to update the `locatedb’ database.”
I disabled it, lets see if this helps.
Stefan
