I am away from home and trying to connect to my WD drive on my mac. iTunes was working fine as I was remotely creating a playlist. Now, its gone from my iTunes and I can’t select it. However, I can access the drive and the music via Safari and my iPhone? All help appreciated as music is needed for a Halloween party
Hello miniminx007,
http://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support:
