Resolved. Thank you
From what I’m finding out, you’re not going to get that from the SMP.
Go back and load default theme.
I do not know. Try the Alaska theme.
@munchhko
my Alaska theme is a NON-Moviesheet Theme … so that will not help you
Nobody can see the images you posted until the are approved by moderators.
(which can take 24hrs or longer on weekends)
(try a external imagehost for instant pictures … eg imageshack, photobucket etc)
@munchhko
Well, the 1st incorrect thing is …
which you don’t have.
take your movies out of their folders … standard moviesheets will not work with movies inside folders.
Have ONE MAIN folder ie. MOVIES and then place your Movie Files inside it.
Yes with my Alaska Theme all you need is a Main Movie Folder … and inside it
eg.
Tron Legacy.mkv
Tron Legacy.xml
Yes, Movie Info does display quickly (i did omit a few things like Cast/Year … wanted to have plenty of Room for the Plot.
But you can still view the Cast/Year in ‘info’ view … Option Button / View Info)
