Hi All,
I have a WD Studio 1TB which was used on a macbook to just hold some additional data. I now want to use it for 2 things.
1 - Back Up with Time Machine to keep my work data backed up.
2 - Store my itunes music/videos on as my data exceeds the HD size of the macbook. Ideally I will link itunes to the WD Studio so I don’t have to store music on the macbook hd.
At present all I have on my WD Studio is my itunes music and vids, all other documents etc is on the macbook drive. What I would like to do is partition my WD Studio to say 500GB back up facility and 500GB itunes.
Can you tell me if it is possible to partition my drive while data is still on it as I don’t really want to move my itunes stuff. Secondly can you point me at the link that tells me how to partition as I am not sure how to do it.
Thanking you in advance.
Matt
