Anyone know how to undo a command on ThumbGEN Designer?
I think you should post your question in the off topic section.
Hello
Undo/Redo is the next feature I plan to add to the ThumbGen Designer. For the moment you cannot Undo operations there. I know it is annoying, I’ll have it done as soon as I’ll work again on the ThumbGen apps.
