I’ve got a central storage server in my home running OpenIndiana/napp-it (ZFS) - The ZFS folder (datatstore/media) is shared as an NFS share with i believe the correct rw,root=@ privliages. I am able to connect and browse my files on the WDTV however when I click on play, it sits as if it is trying to load.
I am almost certain its not a permissions issue, as I am able to mount the same NFS share inside osx and read/write from it.
I googled, and found an identical issue however I don’t know how to apply this “fix” as I am not running windows;
What I don’t understand is that I can mount the NFS inside two different computers - one OSX and the other Win7 - and read/write to them with absolutely no issues. I know its not a hardware issue because the two computers above are connected to the same network.
Inside my home I run an HP 1810-24G switch with an Asus RT-N66U router. I believe this is a permissions error of some sort… ughh cant seem to figure it out.
