I am trying to get movie sheets displayed on my hub and wasn’t successful. I spent lot of time this weekend on this/read through tutorials/threads but still could not get mine to working .
I have my movies stored under individual folders and for the themes i downloaded extreme’s mega pack 3.0 and i tried each and every theme on available on that pack trying out all kinds of views (gallery,large grid,small grid ,list view ) but could not get my movie sheet displayed .
I used thumbgen and downloaded all my movie sheets. I checked all the movie sheets have been created perfectly .
All my movies are stored on hub’s internal hard drive .
I am not able to understand where i am doing wrong ,any help is much appreciated.
My folder structure: Movies\blurays\21 … movies in individual folders
I dont need lot of varieties all i need is my movie sheet to look like this. Pls help me with the theme i should use to get this type of movie sheet and the view i should select on hub to get this.
Any help is much appreciated .
Thanks for all creators of themes & movie sheet templates , Guys you rock…
In your example of a folder called 21 you should have
21.mkv --------> the main movie
21.mkv_sheet.mkv ----> dummy file (see my post about using a movie trailer for this file)
21.mkv_sheet.jpg -----> moviesheet compatible with hub and live players
21.xml -------> metadata
folder.jpg ---------> custom coverbox usually the same as (21.jpg)
Furthmore i see from your post that you keep the movies on the Hubs internal drive, so normally the moviesheet will only show when you hover on the dummy file and the dummy file will normally show after the main movie so you have to press the ‘right button’ on the hubs remote for it to show…
My advice would be to hightlight the dummy file so that the moviesheet shows and the rate it 5 stars. Then make sure that the Hub sorts by ratings v hope that helps…
i have all the files mentioned as per your post ,but i dont find an xml file in my folders , i am not sure how do i get it . should it be generated by thumbgen or do i have to create one.
you can see how the files in my hub for movie avatar. Pls tell me how to add or generate xml file.
