My WD Element Turn Off And Turn On Itself And Im Replace USB Cable Same Problem
Note: This **bleep** In USB 3
Check your power settings and see if sleep is enabled for USB.
Joe
Thank You Sir But Im Owner Another 5 Wd 2 500GB & 3 1TB … Model WDBPCK0010BBK-EESN
Work Smoothly But This Model WDBU6Y0020BBK-EESN 1 & 2 TB Problem In Port USB3
My MB MSI Z68A GD65 G3
Hint This situation appears when transferring files and when things are normal sleep And along Turn On Normal
