Can anyone interpret this output?
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 224) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 199 199 021 Pre-fail Always - 3016
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 12
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 070 070 000 Old_age Always - 22309
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 12
16 Unknown_Attribute 0x0022 001 199 000 Old_age Always - 107275331812
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 3
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 22
194 Temperature_Celsius 0x0022 115 097 000 Old_age Always - 32
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
Warning: ATA error count 27192 inconsistent with error log pointer 5
ATA Error Count: 27192 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It “wraps” after 49.710 days.
Error 27192 occurred at disk power-on lifetime: 22309 hours (929 days + 13 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 63 08 f8 36 12 e8 Device Fault; Error: ABRT 8 sectors at LBA = 0x081236f8 = 135411448
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 08 f8 36 12 e8 00 30d+22:41:01.397 READ DMA
47 00 01 13 00 00 a0 08 30d+22:41:01.393 READ LOG DMA EXT
47 00 01 00 00 00 a0 08 30d+22:41:01.389 READ LOG DMA EXT
ef 10 02 00 00 00 a0 08 30d+22:41:01.387 SET FEATURES [Enable SATA feature]
ec 00 00 00 00 00 a0 08 30d+22:41:01.384 IDENTIFY DEVICE
Error 27191 occurred at disk power-on lifetime: 22309 hours (929 days + 13 hours)
c8 00 08 f8 36 12 e8 00 30d+22:41:01.255 READ DMA
47 00 01 13 00 00 a0 08 30d+22:41:01.252 READ LOG DMA EXT
47 00 01 00 00 00 a0 08 30d+22:41:01.247 READ LOG DMA EXT
ef 10 02 00 00 00 a0 08 30d+22:41:01.245 SET FEATURES [Enable SATA feature]
ec 00 00 00 00 00 a0 08 30d+22:41:01.243 IDENTIFY DEVICE
Error 27190 occurred at disk power-on lifetime: 22309 hours (929 days + 13 hours)
c8 00 08 f8 36 12 e8 00 30d+22:41:01.114 READ DMA
47 00 01 13 00 00 a0 08 30d+22:41:01.110 READ LOG DMA EXT
47 00 01 00 00 00 a0 08 30d+22:41:01.106 READ LOG DMA EXT
ef 10 02 00 00 00 a0 08 30d+22:41:01.104 SET FEATURES [Enable SATA feature]
ec 00 00 00 00 00 a0 08 30d+22:41:01.101 IDENTIFY DEVICE
Error 27189 occurred at disk power-on lifetime: 22309 hours (929 days + 13 hours)
c8 00 08 f8 36 12 e8 00 30d+22:41:00.972 READ DMA
47 00 01 13 00 00 a0 08 30d+22:41:00.969 READ LOG DMA EXT
47 00 01 00 00 00 a0 08 30d+22:41:00.964 READ LOG DMA EXT
ef 10 02 00 00 00 a0 08 30d+22:41:00.962 SET FEATURES [Enable SATA feature]
ec 00 00 00 00 00 a0 08 30d+22:41:00.960 IDENTIFY DEVICE
Error 27188 occurred at disk power-on lifetime: 22309 hours (929 days + 13 hours)
c8 00 08 f8 36 12 e8 00 30d+22:41:00.831 READ DMA
47 00 01 13 00 00 a0 08 30d+22:41:00.827 READ LOG DMA EXT
47 00 01 00 00 00 a0 08 30d+22:41:00.823 READ LOG DMA EXT
ef 10 02 00 00 00 a0 08 30d+22:41:00.821 SET FEATURES [Enable SATA feature]
ec 00 00 00 00 00 a0 08 30d+22:41:00.818 IDENTIFY DEVICE
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
1 Short offline Completed without error 00% 22309 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
thanks all
