10tb G-Drive “vs” 12tb G-Raid
I have new 16-17 MacBook Pro w Thunderbolt 3, 1Tb internal SSD and FCPX installed.
I want to get an external drive so I can keep my internal drive clean. I plan to keep ALL my files on external drive. Programs will be installed on internal ssd. My plan is to set up FCPX (installed on internal ssd) so that I “leave files in place” so that FCPX will simply “reference” videos that are stored on an external drive (when editing). I will also store all completed projects on the external drive.
Q: Would G-raid (at raid 0) be worth the extra investment “vs” G-drive as far as performance w fcpx (set up like mentioned - leaving files on external drive)? …Would there be a noticeable difference?
Q: Any ADVICE on a back-up options /drives /solutions? …Considering ‘‘backing-up’’ to a WD easy-store $200 5200rpm external drive ONLY bc i can’t think of a better option…Any advice / better idea?
