updated the firmware on my WD live media player. now it won’t recognise my 1tb portable hard drive.
noticed that my smaller flash drives have a wdtv folder on them, is there a program that i cna download to my hard drive so the media player will recognise it?
Try doing a rollback to and older firmware, check if the same problem continues and then reinstall the latest version. Also check if the same problem happens with another 1TB HDDs.
