had a movie on pause on Wd Live Plus and when I went back to it it says I have to unlock it.Thing is I never set a password and when I got the hard drive I reformated it.So I didnt have any of the ■■■■ that came with the drive on there.I want to know how do I figure out the password so that I can unlock it.I downloaded smartware and I am putting in password after password and nothing is happening.I do not want to reformat cause I dont want to lose all of my files that I have since I dont have any back up.it is over 800 gigs of stuff on my hard drive.I would like any help if possible.I do not know what else to do.I dont have a password for it so I cannot unlock it.Please help.
To me the whole password thing is worthless.I dont need password protection on the drive since I am the only one going to use it.The drive made its own password and then locked itself.I dont know how it happened.I have called the so called tech support and it was useless.All they could do Is send me a replacement.So all my files is lost forever cause of a malfunction of the hard drive.I cannot afford 149.00 a hour to get my files back in the third part company.When I got it I fomated the drive which wiped out all of the ■■■■ on there so I dont know how the password got on there.All I know I was watching a movie paused it came back about 2 hours to find out it was asking me for a password.I dont have a clue what happened.I just wish I could figure out a way to fix it but it doesnt look like I will.I may sell this drive they are sending me and get another one that has not passwording in it.Those that do have password stuff is useless.
To me the whole password thing is worthless.I dont need password protection on the drive since I am the only one going to use it…
Well, that’s why the My Book Essentials drives (password-capable) cost more than the Elements drives (not password capable – just a bare drive). You could have saved money in the first place if you hadn’t paid extra for features you didn’t want.
The password features/encryption are on the controller, not on the drive… you can’t get rid of them by formatting the drive. The unlocker application is on a non-removable VCD partition (which may or may not be hidden, but can’t be removed). All you removed was the SmartWare application.
Well, not that it helps you now, but they do tell you that in the manual. Even they can’t access the encrypted data off the drive:
CAUTION! If you forget your password, you will not be able to access the data that is on your drive or write new data to it. You will have to erase the drive before you can use it again.
Warning: WD Cannot retrieve your password. If you forget your password you will permanently lose access to your data.
Yeah well I cant even reformat it now.I couldnt find anything else at my walmart that had no password encription that had 2 TB.If I had I would bought it instead of this paper weight.I never set up a passord so that it what I am so puzzled about.I dont know how a drive can lock itself and then ask for a password if you havent set on up for it.I wish there was a way to remove the password .It says that I can under setting but I cannot get to the setting since its locked.This is just too crazy for me and I am very mad at this whole situation.this should not have happened ever.I never heard of it happening before to anyone else.
How does a drive go dead in only 2 months tho.I dont get it.Just out of the blue with no user error just croak.Maybe it is possible that I got a bad drive I guess.
The drive isnt even showing up on my pc.It does show up on the smartware software tho but it says it locked and when I click on it ask me to put in a password which of course what is the passord is the big question.
If you read the manual you will find that you can use the Unlock utility and after 5 unsuccessful password attempts it allows you to erase your drive (which of course will mean the loss of your files).
Well, if you deleted the SmartWare application off the drive, and hid the unlocker VCD, then obviously you have no access to the Unlocker utility. If you can’t run the Unlocker utility, then you can’t make use of its ability to format a password-protected drive. The fact that you can’t run the utitlity, doesn’t make what the manual says the utility can do if you ran it, a lie.
Well maybe it was removed when I formated it two months ago when I got it.I was hoping that when I formated to ntfs format that I removed all the useless stuff on there but I guess not.So basically there really isnt anything anyone can do to recover my files.
Yeah I read the link but did me not good.I dont need to set up a password I need to figure it out to unlock it which is impossible to do.I just wish there was a reset button to change the password to a default one.
