Seems difficult to believe that nextcloud is not able to run on a HDD…
Update:
Reinstalled docker from Release Docker v20.10.14 for WD My Cloud · WDCommunity/wdpksrc · GitHub.
Now the nextcloud image works fine.
Update:
I’m not saying it’s not working, but it will become slow if you start using multiple applications simultaneously (on a HDD combined with a slow CPU).
Hi @robgar2001 , would you mind sharing how did you install docker (with which command)?
I tried running the bin file you mentioned but I get error syntax error: unexpected ")"
Sorry I am a newbie in this matter.
I am SSHing into MyCloudEX2Ultra, firmware 5.27.157
hope you can help, I really would like to be able to run nextcloud on this device…thanks!
