[GUIDE] How to unbrick a totally dead MBL
Hi Guys,
i do have very many problems  and the Guide doens´t help me :-(…
So i decided to enable SSH and installed minidlna… everything was fine… after this i tried to install an funambol server. My MBL starts no more… so no i try to give my MBL a new life But the Guide herer doesn’t work… PLEASE  I NEED HELP I AM A LINUX NEWBIE…
I used this tutorial:
http://community.wd.com/t5/My-Book-Live/GUIDE-How-to-unbrick-a-totally-dead-MBL/td-p/435724
i deleted all partitions on my mbl drive and added one old IDE harddrive to my system with the files rootfs.img and debrick.sh
booting with the rescue disc is completed and all hard drives are mounted…
BUT AT THIS POSITION THERE COMES THE PROBLEM:
mdadm -S /dev/md0 ./debirck.sh rootfs.img /dev/sdb
mdam: error opening /dev/md0: No such file or directory
mdam: ./debirck.sh does not appear to be an md device
mdam rootfs.img does not appear to be an md device
mdam /dev/sdb does not appear to be an md device
mdam error opening destroy: no such file or ditrectory
Can anyone help me… i am a linux unkown person…
What can i do to get my MBL back to live???
I do not habe any backup of the old systenm the partition table is completly deleted the hard drive is an 2 TB MBL
Regards
Enter each line in the code box by itself 1 at a time into the terminal window followed by the enter key
mkdir /mnt/usb
mount -t vfat /dev/sdb1 /mnt/usb
cd /mnt/usb
mdadm -S /dev/md0
./debrick.sh rootfs.img /dev/sda
Don’t forget to change the drive letters as explained in the guide
Hi again,
thanks for your promt reply…
I enterd each line by itself unsure i was by
mdadm…
i thought i had to enter the complete line like this
mdadm - S /dev/md0 ./debrick.sh rootfs.img /dev/sda
could you please explain for what ist the line mdadm -S /dev/md0 ?!  I searched in google for it and it refers me to software raid system… is this correct?
and the biggest question what is device md0 ?! should this be my dvd rom drive, where the recue disc is in?
the other steps are understandable because i know the commands from the MS DOS system.
But the mdadm -S /dev/md0 line i do not understand…
thanks
That command needs to be entered in 2 seperate lines
mdadm -S /dev/md0
mdadm -S /dev/md0 STOPS the software raid running on your MyBookLive at /dev/md0
md0 is the OS on the MBL which runs as a software based raid and consists of sda1 and sda2
The sysrescue cd sees this and mounts it as md0
The debrick script WILL NOT RUN if there is anything running on md0 and will tell you as much if something is
hi,
thanks for the information - but i cannot reach anything :-(…
My situation:
Lenovo thinkpad t60
1 usb drive ntfs formated with rootfs and debrick script on it
2 usb drive is the mbl drive - one big 2 tb gpt file system without partition
Frist strange thing is that the Kernel setup hangs, when the mbl drive is connected and i get erros, when the mdam dialog comes… when i disconnect the mbl hard drive the recue disc starts up promt
After the startup i connect the mbl via usb and when i hit the dialog
mdadm -S dev/md0
mdadm: error opening /dev/md0: No such file or directory
when i type in the
there comes a screen
script will use the following disk:
and then nothing happens any more… the script hungs up
any ideas geting my mbl back ?!
thanks
You need to change the mount command to reflect the filesystem for the usb drive with the rootfs.img from vfat to ntfs
also remember to check the drive letters in gparted and change them as needed.
mount -t ntfs /dev/sdb1 /mnt/usb
USB to sata cables are very iffy with this script. You might want to try the 2.0 guide linked at the top of the guide on page 1
http://community.wd.com/t5/My-Book-Live/GUIDE-Debrick-MyBookLive-v2-0/td-p/567582
Also since you deleted all partitions you need to use the destroy flag to recreate them
./debrick.sh rootfs.img /dev/sda destroy
i saw the second guide on thje first page but i thought becuase there are no partitions anymore i do have to use the first guide with building the partiotion structure… i thought this is clever…
NEWS:
after 5 min waiting the script goes on … the word destroy i didn’t forget… mounting an ntfs drive and using the correct paths is also not the problem
now there is another question…
Warning blocksize 65536 not usable on the most systems
mkefs
mkfs.ext4 65536 bte blockss too big for system (max 4096)
proceed anyway? yes no?
i choosed no… no it ist checking for bad block… 35 min elapsed and only 0,14 %  and (123/0/0 errors) is it good or bad?
You have to answer yes to the blocksize of 65536
Try quick formatting the MBL hard drive to NTFS using gparted and try running the script again answering yes to the blocksize of 65536
Hi again,
tried everything the night - but i doesn’t help … now i launched my wd hard drive to windows and started wd lifeguard… i made a fuell scan and i got a lot of bad sectors… i think the hard drive is finished…
i have to order a new one… Big question … mit MBL was an 2 TB version … can i order a 3 TB WD Red and put it into the mbl case?  will it work with the here posted guide?
Thanks a lot
I have been told that yes it will work
Been trying to recover data from unresponsive My Book Live 2TB NAS.
Using R-Linux I am getting this constant I/O 1117 error.  Does this mean it is a physical problem and the data is not recoverable?  Thx.
See this photo here.
I’ve tried various other operations and it seems to hang/pause forever.  I did a recovery procedure w/ R-Linux, but it didn’t seem to recover any of my media files.  Which folder are my files located in?  isn’t it /media ?
Any thoughts are appreciated.
Kind regards,
-pro
so yesterday i bought a new wd red and i tried the script with an old toshiba hard drive… but it didn’t work …  any ideas?
root@sysresccd /mnt/usb % ./debrick.sh rootfs.img /dev/sdc destroy
**********************DISK**********************
Model: TOSHIBA MK8032GSX (scsi)
Disk /dev/sdc: 80.0GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
is this REALLY the disk you want? [y] y
**********************IMAGE**********************
**********************IMPLEMENTATION**********************
everything is now prepared!
device: /dev/sdc
image_img: rootfs.img
destroy: true
this is the point of no return, continue? [y] y
dd: writing ‘/dev/sdc1’: No space left on device
11+0 records in
10+0 records out
10485760 bytes (10 MB) copied, 0.0129123 s, 812 MB/s
dd: writing ‘/dev/sdc2’: No space left on device
1+0 records in
0+0 records out
0 bytes (0 B) copied, 0.000972191 s, 0.0 kB/s
dd: writing ‘/dev/sdc3’: No space left on device
1+0 records in
0+0 records out
0 bytes (0 B) copied, 0.000831251 s, 0.0 kB/s
dd: writing ‘/dev/sdc4’: No space left on device
1+0 records in
0+0 records out
0 bytes (0 B) copied, 0.000795841 s, 0.0 kB/s
Testing with pattern 0x00: done
Reading and comparing: done
GNU Parted 3.1
Using /dev/sdc
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) mklabel gpt
(parted) mkpart primary 528M 2576M
(parted) mkpart primary 2576M 4624M
(parted) mkpart primary 16M 528M
(parted) mkpart primary 4624M -1M
(parted) set 1 raid on
(parted) set 2 raid on
(parted) quit
Information: You may need to update /etc/fstab.
Warning: blocksize 65536 not usable on most systems.
mke2fs 1.42.7 (21-Jan-2013)
/dev/sdc4 is not a block special device.
Proceed anyway? (y,n) y
mkfs.ext4: Device size reported to be zero. Invalid partition specified, or
	partition table wasn't reread after running fdisk, due to
	a modified partition being busy and in use. You may need to reboot
	to re-read your partition table.
destroying was done, would you like to continue with installation? [y] y
mdadm: size set to 10176K
mdadm: ADD_NEW_DISK for /dev/sdc1 failed: No such device or address
mkfs.ext3: Device size reported to be zero. Invalid partition specified, or
mdadm: cannot get array info for /dev/md0
synchronize raid... done
copying image to disk...
dd: writing to ‘/dev/md0’: No space left on device
1+0 records in
0+0 records out
0 bytes (0 B) copied, 0.0190004 s, 0.0 kB/s
mount: /dev/md0: can't read superblock
cp: cannot stat ‘/mnt/md0/usr/local/share/bootmd0.scr’: No such file or directory
./debrick.sh: line 359: /mnt/md0/etc/nas/service_startup/ssh: No such file or directory
umount: /mnt/md0: not mounted
mdadm: stopped /dev/md0
BLKGETSIZE: Inappropriate ioctl for device
all done! device should be debricked!
I have no more ideas … i will try the 2nd guide and report again…
Kind regards,
-pro
The drive sounds to be dying but you may be able to pull your data off a little at a time. The data is located in the /DataVolume/shares folder. You may need to turn to a professional data recovery company if the data is irreplaceable and the above doesn’t work
@MJB0006 sometimes you need to run the script a second time after the partitions and table have been created. You will want to completely shut down the computer and boot the sysrescd and try again. If it doesn’t work, guide 2 is your best bet
Kind regards,
-pro
What do you think of this?
Nothing shows up in the DataVolume.  It only located maybe 15-20% of file names and I cancelled.  But here it shows 0 under DataVolume.  Do you think some how the drive got wiped out (formatted) or the hardware failure is just preventing anything from showing?
-pro
My BEST GUESS would be the hardware failure has trashed most of the data
Thx for your input nfodiz.  Really great to have your responsive help.  Better than WD Customer support line (which told me my data is definitely recoverable).  I hope WD is paying you.
I wish lol, but nope I’m just an end-user just like you that enjoys helping people when I can. Thanks for the kind words and I hope it all works out in the end for you.
