hi,
until yesterday my MBL 1TB was working well (used with 3 pc’s XP Vista en Win7)…
because I wanted to use WD2GO on my phone, I needed the password which I had lost…
So I did a reset with a green blinking light as a result.
Have done 2 more reset attempts - no luck. Tried other router port. Restart router. All without result.
MBL starts up blue-amber-then flashing green - WD disk detection connot detect the drive.
When I try the shortcut on the pc the answer I get is that the address is wrong. Windows problem solving is suggesting it could be a DNS issue? As all other connections and internet is working fine,
dashboard cannot be reached with Chrome/Firefox/Expl
hope anyone can give me some advice to get it back to work?
F
