Hi, My G-SPEED Q 4-Bay 8TB (0G02836) currently isn’t working and is three months past warranty. It appears the drives are fine, but the enclosure has failed. G-Tech support told me they no longer offer this enclosure for sale. I haven’t even found any used ones online. What G-Tech enclosures or after market units will fit with my drives?
Any other G-speed Q enclosure as long as it matches the same USB version yours is. If it is an 8TB unit then it would have the USB 3.0 so any G-Speed Q enclosure with USB 3.0 will support your drives.
OK, bought an enclosure on eBay. Plugged in my drives, all solid blue lights, but while it does mount to my MacBook, when I try to open or copy a file from it, the whole thing dismounts. What’s going on?
