Ftp problem with passive mode
I want to access my book live duo from outside.
I have dynamic dns, open port 20 and 21 and 5000 to 5099.
If i make a test with http://ftptest.net I take this:
Status: Resolving address of ******.dtdns.net
Status: Connecting to 89.210.72.***
Status: Connected, waiting for welcome message
Reply: 220 “Welcome to MyBookLive”
Command: CLNT http://ftptest.net on behalf of 89.210.72.***
Reply: 530 Please login with USER and PASS.
Command: USER admin
Reply: 331 Please specify the password.
Command: PASS ***********
Reply: 230 Login successful.
Command: SYST
Reply: 215 UNIX Type: L8
Command: FEAT
Reply: 211-Features:
Reply: EPRT
Reply: EPSV
Reply: MDTM
Reply: PASV
Reply: REST STREAM
Reply: SIZE
Reply: TVFS
Reply: UTF8
Reply: 211 End
Command: PWD
Reply: 257 “/”
Status: Current path is /
Command: TYPE I
Reply: 200 Switching to Binary mode.
Command: PASV
Reply: 227 Entering Passive Mode (192,168,1,10,19,230).
Error: Server returned unroutable private IP address in PASV reply
What I am doing wrong?
Teonok,
Have you been able to test FTP access within your local network using an FTP client? Are you able to access other FTP-enabled devices on your home network using the same method?
Looks like your router doesn’t support Passive FTP ALG – (“Application Layer Gateway”) so it’s not translating that PASV instruction to use your outside address.
Some routers do, some don’t – and finding documentation on which do and which don’t is darn near impossible.
http://www.ncftp.com/ncftpd/doc/misc/ftp_and_firewalls.html#PASVFirewallProblems
Only option I know of for you is to modify the FTP configuration in the Duo to specify your outside address…  and that’s got its own problems if your outside address changes…
The FTP works fine when I am at the local network. The strange thing is that before I had a WD Mybook World Edition 2 and the FTP worked ok when I was outside with the same router (Thomson TG585 v8).
Ok, I found the solution. I added the line
pasv_addr_resolve=YES
pasv_address=****.dtdns.net
and now it works like a charm!
***.dtdns.net is my host name on dtdns.net
Thank you for your support. The strange is that with mybook world edition 2 worked without this line
