I would suggest turn it right off. (Hold power button for over 8 seconds) Now remove the power lead and let it sit there for a good minute or so.
Now put the power lead back in and see how it goes.
Whenever my WDTV plays up, does something weird, the sound goes way out of sync, a movie file won’t play etc this is what I do and when it restarts from a ‘cold’ start everything works fine again.
It may not work in your case but could be worth a try.
thanks for your replies, sometimes it comes back, and this morning it did the same again. It gets way to hot. [Deleted - Trancer] design.
I unplugged it for a long time and came back again once but now it blinking again. The ticking sound is something most switchmode spower supplies doe when they are of a **bleep** design, the airgap in a coil can create that sound.
I when I unplugged the powersupply (the littel brick) it comes back, lets see if can stay alive for a week but I suspect the powerspply is the issue.
You may have a defective unit if it’s more than barely warm.
I just measured mine with an infrared thermometer after watching videos for the last 3 hours… temperature is 103.8 F at its hottest point on the top of the case while ambient temperature is 76 F.
If I were that temperature, I’d go to the hospital – but for a compact electronic system, that’s quite normal.
If you have a USB device attached, check the temperature of the USB plug. Most blutooth receivers don’t get warm at all – but many memory sticks get VERY hot because they’re not made for the 24x7 read/write access the WD hits them with.
This is a red herring.
Let’s assume for a minute that the WD did use a SMPS. The power supply is in the wal-wart – not the WD case. So would not explain a sound coming from the case. The only power-supply system in the WD TV case is a 12V DC voltage regulator which is solid state. Also, a ticking (failing) SMPS does it constantly when energized – not just the moment when the power is shut off.
But this is meaningless as he WD’s power supply isn’t a switched-mode power supply; it’s just your basic old transformer / full wave bridge rectifier / filter capacitor design.
apologies for asking … you are using the supplied WD power supply 12V DC 1.5Amp ?
(just asking because i accidently left my WDTV power on for about 18 Hrs … and it was only “Warm” … if you’re using a power supply with Less than 1.5Amp then yes… it will get Hot and eventually burn out)
indeed, everything stock; however when the led is flashing there is no screen output and no network connectivity (ie it doesn’t show up on the network)
