Can anyone tell me why this and others won’t play? They appear in the WD player but when I hit play it just sits there doing nothing. Here is the mediainfo .txt file. Will I have to roll back the firmware? I am using the latest FW.
Rolled back FW to1.05 and everything seems to be o.k. now. Hopefully WD get’s this problem fixed.
Hmms, i’m using the latest firmware 1.07.18 and don’t have such problem.
I can play flac files just fine
Don’t know why, but I had some Flac files that would play and some that would not before.
can you upload one of this flac file which refuse to play,[you can PM me a link to it] to try it at mine wd live?
You never added anything about these files which do not play - there is no mediainfo.
Thanks for the help…in my last post I said that I rolled back the FW and everything is now working.
