Preface: I have/had a 2TB Mybook world edition II setup with Raid 1.
I managed to get my files off it. I used my thermaltake blacx duet over usb to mount the drives. If you had them setup in Raid 1 (mirror) then you only need one of the drives. Just take it out and attach it to your motherbooard directly.
Step 1. Get Linux
You have two options here.
The easy way: Boot from a live distro (Knoppix, Suse, Live Ubuntu, etc) (essentially whatever floats your boat)
Or just install it. In my case I used the disk management tool to shrink my storage partition on my desktop by 20GBs; more than enough to install linux and installed openSuse 11.3 on it.
Step 2. Mount the raid volume
Open terminal/console
Login as root:
su root
If your distro doesn’t come with mdadm then install it. On Suse this was already installed. If not use:
apt -get mdadm
use this command to assemble the raid array:
mdadm --assemble --scan
Your array should now be mounted with 4 partitions; the last partition which uses XFS as its file system is the data partition. From this point you can use any file browser (Dolphin in my case) to browse the drive.
From here you should be able to read and write as you wish. Either map a network drive and copy the files or attach another external drive and copy the files over.
Hope this helps.
Now that I can mess with the file system i wonder if there is a way to somehow restore the drive’s firmware.
Any updates to this problem…I made the same HUGE MISTAKE this morning…After talking to phone support for a while they determied the drive is bad and needs to be replaced…I MUST get the data off this drive…Going to try the above mentioned linux magicks!
Same problem here. Pushed the “Upgrade” button yesterday and the unit is now blocked at the lower white led, lots of disk activity, green light only on the network interface.
Made the mistake of update firmware without checking this thread and now it is stuck in infinite reboot loop at the startup. Any suggestions as downgrading firmware doesn’t seem to be an option here.
Sending the disk for RMA is not an option - so I’m thinking of extracting the disk from case and mounting it on a SATA to USB station??
WD people - you need to STOP distributing this firmware asap.
Thanks! I agree - attaching the disk another m/c seems the be the only viable option right now. I dont have a desktop m/c so I’ll need to buy the SATA/USB adapter station and connect it to my laptop. I hope the data is still intact !
Mods - please escalate this issue now - someone in WD needs to pull the plug and STOP DISTRIBUTING this firmware.
