I have updated to this revision and I am facing the following issue :
When the power is down after turning it on, it takes around 20 to 30 seconds to send any signal to my TV.
During this mean time the front panel WD light is ON (however the configuration is off by setup),
Also, the internal Hard Disk is off and internal fan is off.
After this time, the WD shows LOADING on my TV, then WD light turns off .
That Loading phase takes more 30 seconds to be ready.
So, now in total it takes around 1 minute for complete start up.
That behavior didn’t exist in the original revision 2.04.13 when I bought the WD player. Before was very fast during this start up. Around 10 seconds it was ready to use.
Also, when everything is up, then I press the Turn off button on remote control, the player freezes for 5 seconds before OFF.
Can anybody tell me if this behavior is correct with this newest revision ?
The most strange for me is the first 30 seconds when nothing is done before start loading.
Thanks,
Evandro
obs. : The hard reset (the button below of the hardware) has been tried. But the result is the same. Too slow start up.
