Fan Not Working Error. Fan is physically working
I bought a brand new My Cloud Ex2 Ultra NAS for use at home. It works fine and the fan is usually on with no issue and when I check system health it shows a working fan and it is physically working.
However, I keep getting fan not working errors in the system Dash Board. Is this a software Issue? They seem to come at around the same time each day around sun set. Is it some thing I should be worried about?
|2022 Mar 14 18:57:34|FAN|The system fan is not working.
|2022 Mar 13 20:45:40|FAN|The system fan is not working.
|2022 Mar 13 20:34:38|FAN|The system fan is not working.
Chathura
Hi Chathura
I have the same issue and it started after a firmware update, do not remember when.
When I realized the fan was working fine, I decided to ignore the warnings.
They will probably fix this in a future firmware update.
Maybe, maybe not. I’d return it for a replacement if its under warranty.
