My EX4100 won’t power on. The external power supply has been checked and found in order.
Any ideas?
Any ideas?
It is recommended to plug the power adaptor directly to a wall socket rather than using a power strip, if that does not help you may try with a different power supply.
Hi Jonty,
thank you for the reply. I’ve tried both but no result.
