I recently moved and cant locate the power supply for my EX4. Can someone please take a look at their power brick and tell me what the output specs are? I can’t find this information listed anywhere and need to find an appropriate power supply so I get the EX4 up again.
Also the plug is 5.5mm outside diameter and 2.5mm inside diameter. The original APD brand pwr supply is not generally available, but equivalents are routinely found on Amazon.
In theory, you can call up WD and if you whine and beg enough, they might sell you one.
