Ever since the recent firmware update the capacity indicator on the dashboard home page indicates only the number of TB’s free. It no longer breaks this number down into different types of media files as it did prior. I had made no other changes during this period. Media streaming is ON and the Settings/Media page breaks the files down into the number of Music Tracks, Pictures & Videos.
I have done the following with no change:
rebooted
rescanned dnla database
rebuild dnla database
shutdown at the front panel physical button and restarted.
Any insight into this issue would be appreciated.
I use the dashboard at http://wdmycloudex2100/ , if that’s what you mean. If your question is about the “Cloud Access” page of the dashboard, that is disabled.
As Lutz mentioned before, this is the reason behind. Cloud Access disabled causes the Dashboard to show only free capacity. Cloud enbaled and you will see the separated capacities in use. This is bound to the media crawlers of the cloud access feature.
