Hi.
Does WD update cover art on shared drive.
I was able to hit option on one dvd iso file and it worked, but for some reason I cant get it to work on anything else.
Thanks.
Joe
Hi.
Thanks.
Joe
Yes, it does.
Thanks tony.
I have it to do this automatically, but for some reason it does not happen.
Even if it is set to do it manually, there is no get info in the option for the the folder.
…Joe
Do you have your Content Source set to “My Media Library?”
I am going to linux network share. I have a wdlive network drive.
I should use my media library?
Yes, you MUST use My Media Library to have the option to “Get Content Info.”
thanks Tony.
