I use WD Smartware v2.4.16 for my WD 3Tb MyBook. I bought/added a WD Wireless Pro but it doesn’t show up in that software.
Do I need to buy the Pro Smartware version to be able to manage the backup of both drives?
I noticed the Wireless Pro comes with Smartware software but I’m guessing it’s the same as what I already own? so I didn’t try to install it.
Hi maarkr,
With the Wireless Pro you need to use the software called WD Backup. Check these instructions on how to install it and how to use it:
How to install WD Backup
Backing up files using WD Backup
