I have a My Passport Elite 250GB (wdbaac3200ach) that isn’t being detected, not even as a USB device when plugged in. The drive itself seems to spin up etc…
Does anyone know if there is a hard drive with a SATA interface inside? Or is the USB connector directly on the drive? I’m hoping I can just break the enclosure, and disconnect a possibly fried controller board, and connect to the drive via SATA directly.
The data is encrypted by a circuit board, it’s nothing you turn on and off. You might be able to find another bridge board on Ebay. This explains a bit about the boards http://community.wd.com/t5/Off-Topic-Discussions/Bridge-Boards/td-p/353839 I assume you’ve tried another cable, port and PC. Also don’t use a hub to connect or a cable longer than the one supplied.
