Hi
When I go to the control panel on my WD Mycloud 4TB I get the error message “Data volume failed to mount”, also there is a red light on the front panel. Is there a way to solve this? The disc’s webpage, eg http://192.168.1.nnn/UI/ is working, and I can see the shares, users, and settings.
The disk is mainly used for backup from other computers (both Mac and PCs).
I have searched the forum, and one solution is that it cluld be a faulty ethernet cable, but I have changed it, and it didn’t help. I have read about the SSH solution, but I don’t know how to connect to the device. Can I do this from my Mac’s terminal-window?
I want to try to fix the disc before I do a factory reset.
