Data volume failed to mount
Hello dear community,
I’ve been a very satisfied owner of a MyBook Live since some days now.
However, being so enthusiastic about it, I gave it to a good friend of mine to try it out, as he was also interested in getting one. While both of us are into Linux, my friend suggested to install Finch (the console version of the Pidgin messenger) on the MyBook as an “allways-on-chat-client”. Well, apparently everything went well with that - until I plugged the MyBook in after geting it back today.
Since then I keep getting the message “Data volume failed to mount” and a red status LED. The Webinterface keeps saying 0GB/0TB used.
As the SSH daemon is still up and running, I was able to log into the MyBook and check out how much damage was done.
Here are some things I was able to discover:
Output of: /etc/init.d/mountDataVolume.sh
>>>> mount data volume...mount: you must specify the filesystem type
swapon: cannot stat /dev/sda3: No such file or directory
mount: none already mounted or /sys/kernel/security busy
mount: according to mtab, none is already mounted on /sys/kernel/security
Kernel API version: 2
settrustees API version: 2
Pass 1: Checking for parse errors
Could not find device /dev/sda4
Parse error /etc/trustees.conf:0
failed.
Output of: mount
/dev/md1 on / type ext3 (rw,noatime)
tmpfs on /lib/init/rw type tmpfs (rw,nosuid,mode=0755,size=50M)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
procbususb on /proc/bus/usb type usbfs (rw)
udev on /dev type tmpfs (rw,mode=0755)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,size=50M)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=620)
tmpfs on /tmp type tmpfs (rw,size=50M)
/var/log on /var/log.hdd type none (rw,bind)
ramlog-tmpfs on /var/log type tmpfs (rw,size=20M)
/DataVolume/cache on /CacheVolume type none (rw,bind)
/DataVolume/shares on /shares type none (rw,bind)
/DataVolume/shares on /nfs type none (rw,bind)
none on /sys/kernel/security type securityfs (rw)
rpc_pipefs on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw)
nfsd on /proc/fs/nfsd type nfsd (rw)
Content of: /etc/fstab
proc /proc proc defaults 0 0
sysfs /sys sysfs defaults 0 0
tmpfs /tmp tmpfs rw,size=50M 0 0
/dev/md1 / ext3 defaults,noatime 0 0
Content of: /var/log.hdd/kern.log
Feb 9 15:02:29 localhost kernel: drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Feb 9 15:02:29 localhost kernel: md: Waiting for all devices to be available before autodetect
Feb 9 15:02:29 localhost kernel: md: If you don't use raid, use raid=noautodetect
Feb 9 15:02:29 localhost kernel: md: Autodetecting RAID arrays.
Feb 9 15:02:29 localhost kernel: md: Scanned 2 and added 2 devices.
Feb 9 15:02:29 localhost kernel: md: autorun ...
Feb 9 15:02:29 localhost kernel: md: considering sda2 ...
Feb 9 15:02:29 localhost kernel: md: adding sda2 ...
Feb 9 15:02:29 localhost kernel: md: adding sda1 ...
Feb 9 15:02:29 localhost kernel: md: created md1
Feb 9 15:02:29 localhost kernel: md: bind<sda1>
Feb 9 15:02:29 localhost kernel: md: bind<sda2>
Feb 9 15:02:29 localhost kernel: md: running: <sda2><sda1>
Feb 9 15:02:29 localhost kernel: md1: WARNING: sda2 appears to be on the same physical disk as sda1.
Feb 9 15:02:29 localhost kernel: True protection against single-disk failure might be compromised.
Feb 9 15:02:29 localhost kernel: raid1: raid set md1 active with 2 out of 2 mirrors
Feb 9 15:02:29 localhost kernel: md1: detected capacity change from 0 to 2047803392
Feb 9 15:02:29 localhost kernel: md: ... autorun DONE.
Feb 9 15:02:29 localhost kernel: md1: unknown partition table
Feb 9 15:02:29 localhost kernel: kjournald starting. Commit interval 5 seconds
Feb 9 15:02:29 localhost kernel: EXT3 FS on md1, internal journal
Feb 9 15:02:29 localhost kernel: EXT3-fs: mounted filesystem with writeback data mode.
Feb 9 15:02:29 localhost kernel: VFS: Mounted root (ext3 filesystem) on device 9:1.
Feb 9 15:02:29 localhost kernel: Freeing unused kernel memory: 384k init
Feb 9 15:02:29 localhost kernel: Enable EMAC EMI Fix
Feb 9 15:02:29 localhost kernel: eth0: link is up, 100 FDX, pause enabled
Feb 9 15:02:36 localhost kernel: svc: failed to register lockdv1 RPC service (errno 97).
Feb 9 15:02:39 localhost kernel: eth0: no IPv6 routers present
Feb 9 15:06:00 localhost kernel: nfsd: last server has exited, flushing export cache
I’m not really sure if the /dev/md1 really belongs here? I think the behaviour of this device is configured in /etc/mdadm which belongs to some kind of softraid management tool. As the MyBook just contains one HDD, this doesn’t really make sense to me at all.
Could somebody give me a helping hand on this?
Even though it is obviously my own fault as I was the one who gave it away in the first place.
With kind regards
Alexander
Ya’ll have seriously screwed the box up…
There shouldn’t be an md1, but there IS an md0 which seems to be missing on your box…
You’re also missing a mount to /dev/sda4 (which is the DATA volume)
All this junk:
is not present on my box…
Allright, thanks for your response.
Do you have any idea of how to fix all the junk? :wink:
Would it be possible to reimage the drive with a clean partition scheme?
Well, it appears that I am only missing the /dev/sdX devices, as /dev/md1 holds my root filesystem.
Eeven though it should be called md0 according to /usr/local/sbin/disk-param.sh.
according to /proc/mdstat /dev/md1 is made up by the following:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md1 : active raid1 sda2[1] sda1[0]
      1999808 blocks [2/2] [UU]
unused devices: <none>
while dh -kh shows that /dev/md1 holds the root volume
Filesystem Size Used Avail Use% Mounted on
/dev/md1 1.9G 1.1G 723M 61% /
tmpfs 50M 0 50M 0% /lib/init/rw
udev 10M 256K 9.8M 3% /dev
tmpfs 50M 0 50M 0% /dev/shm
tmpfs 50M 2.3M 48M 5% /tmp
ramlog-tmpfs 20M 3.2M 17M 16% /var/log
What confuses me is that there is no sign of /dev/sda4 or any sdX in general.
The only occurance is in /sys/block/sda which contains the following. A block device, however, looks different.
Output of: ls -l /sys/block/sda-r--r--r-- 1 root root 65536 Feb 9 16:00 alignment_offset
lrwxrwxrwx 1 root root 0 Feb 9 16:00 bdi -> ../../class/bdi/8:0
-r--r--r-- 1 root root 65536 Feb 9 16:00 capability
-r--r--r-- 1 root root 65536 Feb 9 16:00 dev
lrwxrwxrwx 1 root root 0 Feb 9 16:00 device -> ../../devices/plb.0/4bffd1800.sata/host0/target0:0:0/0:0:0:0
-r--r--r-- 1 root root 65536 Feb 9 16:00 ext_range
drwxr-xr-x 2 root root 0 Feb 9 16:00 holders
-r--r--r-- 1 root root 65536 Feb 9 16:00 inflight
drwxr-xr-x 2 root root 0 Feb 9 16:00 power
drwxr-xr-x 3 root root 0 Feb 9 16:00 queue
-r--r--r-- 1 root root 65536 Feb 9 16:00 range
-r--r--r-- 1 root root 65536 Feb 9 16:00 removable
-r--r--r-- 1 root root 65536 Feb 9 16:00 ro
drwxr-xr-x 4 root root 0 Feb 9 16:00 sda1
drwxr-xr-x 4 root root 0 Feb 9 16:00 sda2
drwxr-xr-x 4 root root 0 Feb 9 16:00 sda3
drwxr-xr-x 4 root root 0 Feb 9 16:00 sda4
-r--r--r-- 1 root root 65536 Feb 9 16:00 size
drwxr-xr-x 2 root root 0 Feb 9 16:00 slaves
-r--r--r-- 1 root root 65536 Feb 9 16:00 stat
lrwxrwxrwx 1 root root 0 Feb 9 16:00 subsystem -> ../../block
-rw-r--r-- 1 root root 65536 Feb 9 16:00 uevent
Did you manage to get your data back?  I have the same problem since the power break down while the drive was in use.
There is NO WAY I loose the data on it.
Any help from WD would be helpful since they’ know what’s inside their product !
hi… had the same problem and what helped is to uninstall/install the udev
aptitude uninstall udev
and reinstall it again (reinstall didn’t work for me)
aptitude install udev
then reboot
reboot
as far as I can guess, there is some issue with newer version of udev and old configuration in /etc/udev/
but who knows :slight_smile:
Reminder to myself…  “Enable the SSH daemon and NEVER disable it for that simple action may save me from not being able to troubleshoot.”
I’m also going to try take a copy of every configuration file on the NAS!
Question…  What are the correct commands to check and fix the filesystems/partitions/volumes/files?
