I tried several Sandisk with my iPhone 15 pro but with no luck. Tech support advised me that Apple Files app can be used to move files for models with Type-C connectors. If anyone used that app with their iPhone 15 , please guide me with some details. Thanks
Update: I found the answer:
- I bought SanDisk ultra Go to USB-C flash drive
- I connected the flash drive to my iPhone 15 pro max
- I opened Apple Files App ( blue color file ) usually already installed in your iPhone, if you don’t see it then either you search for it in your iPhone or download it from your App Store
- go to browse in your Files app and you will see SanDisk drive as one option to select.
So if I want to transfere a movie from my iPhone to the flash drive so I can clear some space in my iPhone , you select it and then you share it with your File app and choose SanDisk drive then save.
