CHKDSK not working (DIRTY)
@latheofheaven Hello. Please would you be able to send me the Windows 7 64-bit hotfix if you have it? Unfortunately the link I followed only has the one for Windows 8.
Error 0x80071ac3 – Volume is Dirty occurs when Windows fail to access and read a drive volume or data on an external storage media such as hard disk, thumb drive, or SD card, etc. The error indicates a severe problem with the storage drive, which can result in permanent data loss.
Below are few solutions you can try to fix:
  1. Unlock SD card
  2. Run CHKDSK scan
  3. Run File System Utility check
  4. Use error checking tool
  5. Edit Registry
  6. Disable ReadyBoost
  7. Update device’s driver
  8. Run SFC scan
Further, You can check out the below link for more causes & solutions to fix the issue:
Hope it helps!
Hi Abominog, do you still have it (that one for Win 7) somewhere…? I am having exactly the same problem you described, though with Win 7, the fix for which was removed from the Microsoft site. The Win 8 version which replaces it online does not work with Win 7. If you still have it somewhere (I couldn’t find it elsewhere online) it would really help… Cheers
