Charge battery
Battery will not charge. This device is only 2 years old. any suggestions
The My Passport Wireless Pro may not charge under the following conditions.
  • OEM 12 Watt 5 Volt 2.4 Amp power adapter not being used
  • Power adapter prongs not connected to an efficient supply of power
  • External USB device attached to the USB port
  • Constant disk read or write activity
  • Plex Media Server indexing content
Please refer below link for more information:
https://support-en.wd.com/app/answers/detail/a_id/3925
the first 3 conditions have and are being met, the other two you have to connect to dashboard. How do I do that with Wirelesspro connected to my MacbookPro with usb?
| Keerti_01 ActiveScale Users
June 22 |
@chiefdeck For accessing the Dashboard on a My Passport Wireless, Wireless Pro device, please refer to the link below:
https://support-en.wd.com/app/answers/detail/a_id/19786
Also, I would suggest to perform Diagnostics test to understand the drive’s condition: My Passport Wireless: Drive Diagnostic Test
I can not conect to dashboard!!! I do not get a wifi light!!!So how do I diagnose if I can not connect to dashboard??? Stand by your product and replace, even though this is past warranty it should not fail!!! What kind of company are you???
We appreciate you for sharing the information, I would request you to contact WD for Technical Support: http://support.wdc.com/contact/index.asp?lang=en
